What year model is this suzki 6HP?
TheBrain
Thanks STB
I though the year could be determined by the paint job?
I will try to obtain the serial #
will he short shaft be to short for my 4" transom?
STB
That is a 1994 6hp. Although they are all the same from 1984-1994 then they moved the pull start from the front corner to the top of the flywheel until 2002.
being this old could be a good thing back then engines had better build quality being made in Japan.
will I be able to connect a I troll eletrictric throttle control? TB
The cavitation plate on engine should be almost level with your keel's lowest point on transom. Cavitation plate is the one running horizontally with the hull.
