What year is this
"RX-13B is a 1965 33hp Johnson
"RX-13B is a 1965 33hp Johnson.
Relying on memory, I believe that the lower units will interchange."
The " common parts " m
The " common parts " manual has RX 13 gearcase assembly #593515 and the 74 40 as #386609. Gearcase housing only RX 13 is #593514 and the 74 40 as #386052.From that info it may not interchange.
The manual also shows the same
The manual also shows the same driveshaft for 33hp motors and 40hp motors up to 73 then in 74 the 40hp has a different part # for the driveshaft.
"If it will bolt on,Does it ma
"If it will bolt on,Does it matter about the part numbers. Thanks for the info.
Ken"
"No I guess not.Let us know ho
"No I guess not.Let us know how it goes,these projects are always a learning thing."
Won't go the drive shaft i
Won't go the drive shaft is smaller on the 33hp than it is on the 40 hp. thanks for all the info
Ken
