I had a 115 of the last year produced/sold.....88/89. It had the ported piston and whatever else went with Mercs Direct Charge engine. It was on a 17+ foot Ranger Fisherman which is a solidly built (pretty heavy) bass boat pad hull with a walleye layout. I had a 10 gallon built in tank in that boat and never went out and ran out of gas. I marveled at how fuel efficient that engine was. I'd play at WOT from time to time, but usually I was running around 2/3 throttle. That boat, on the pad could do 35 easily with low hull drag at that point.
I always suspected that part of the reason was the way I had it propped. At WOT trimmed correctly, the engine ran a solid 6000 rpm. Ran it for 7 years and sold it to my SIL. Being 500rpm over upper limit told me that I had the 2 stroker lightly loaded and the DC porting didn't hurt as Merc came out with that to compete with the OMC loopers while the OMC patent was still in effect and we all know how fuel efficient loopers are as compared to cross flow engines. I don't know when they DC'd those towers. Not sure on the 82 year model. But I am convinced that lightly loading a 2 stroker gets you better engine hygiene, better all around performance, and less fuel consumption for a given set of conditions.
So, I'd look for something to change that could improve your economy and letting the ponies out of that engine to me would be the first place to start....unload it somewhat from where you are running. What's your WOT rpms?
Totally agree with galamb and running at cruising speed where he mentioned, rather than WOT....if your boat stays well into the plane position.....minimum hull drag. If cutting back there puts you down in the water where you make a large wake and all, you will offset any fuel improvement in the engine, by boat drag. Years ago Merc used the term "Back Drag Carburetion". You pushed the throttle to the wide open position, let the boat come up to speed, then cut the throttle 1/3 which put the setup right where galamb said. Just a bunch of sales hype on naming it (opinion) but on performance it worked. Nothing different or special about the carbs (opinion).....like what kind of tricks can you play with a venturi, bowl of gas, and a butterfly?
HTH,
Mark
