What year is my mercury
"IF you are taking about the l
"IF you are taking about the lower crank seal, it's a piece of cake. Remove the power head, dig out the old seal, then press a new one in its place. The cases don't even need to be split.
Jeff
PS: I drove a couple of sheet metal screws into the old seal, then yanked it out with pliers."
"Ben, it sounds like you are r
"Ben, it sounds like you are referring to the thrust hub (behind the prop and (sometimes)a "cap" that looks like a washer).
If so, it should simply slide right off, although after 20+ years of sitting in place, it may be a little reluctant to move...
The diagram below isn't the greatest, but #59 will be the thrust hub - is that what you are getting at?
"that looks like it, is there
"that looks like it, is there a website where i can
get more diagrams for this motor. I dont have a
manual for it, and could use the info badly.
thank you for the help, it has been a life saver,
plus i really have an itch to go fishing."
