"Sorry for going off topic, bu
"Sorry for going off topic, but this is the most popular section of the board and by posting here I figured I had the best chance of a response.
In the case of my FWC block only V8, the mechanics advice was always to run it at 170F with a 160F thermostat ( which I did ) as the oil needs to be at least that temperature to disperse the contaminants, and condensation etc.
I fitted a new double pass heat exchanger and it has dropped the temperature to 150F, regardless of how fast or hard I run it.
I asked the mechanic if we should start to play with the thermostat to get the temperature back up, and his comment was, " Well if it was a raw water cooled motor it would run at about 150F with a 140F thermostat." So we will leave it alone.
Does this mean that the oil never does it's job on RWC motors, or is this whole oil thing smoke and mirrors?
I currently use synthetic 15W50, oil pressure is 65 psi @ 3000RPM and about 30 psi at idle 700 rpm.
I would appreciate any comments as to whether I should get the temp back up, or just do what I have been told.
THanks in advance for your time to reply.
Ray"
Ray"
