I'm about to remove ... ahem...... Try to remove ... the powerhead from my 1991 40hp 2str. 4cyl. engine. I've disconnected all the ancilliaries and have cleaned up and being WD-40'ing the hell out of the 8 x nuts for the past 48 hours. Trying desperately to avoid bolt/stud breakage. The only thing is I'm a bit unsure as to what spanner to use - I only have metric and my 10mm is too small and 11mm too loose - I guarantee it is going to round the nuts - So reckon as it's an American motor I will need to buy an imperial spanner but there doesn't seem to be much available between the 10mm and 11mm size. Is 13/32 the correct size ? Anyone know for sure ? - The Nut is officially listed as 11-64809 - NUT (5/16 IN.) at http://www.hbmmercruiserparts.co.uk/...nd=543&bid=140 I guess that 5/16th is referring to the thread size.
See Nuts at : http://flic.kr/p/bvY7Bv
See Engine Details at : http://flic.kr/p/bvY7Bn
Cheers
Cheers
