what shouuld the compression be?
Note that each cylinder being tested was cycled through at least 3 compression strokes.
This is necessary because the test gauge and hose itself is accumulative until they equalize to max cylinder pressure.
Ayuh,..... 150 psi, 'n up is a strong motor,....
125 to 150 psi is an Ok motor,.....
100 to 125 psi is a worn motor,....
Under 100 psi is a rebuildable core motor,....
