What should rpms be at full throttle
daneryden
i have a 130hp honda and its o
i have a 130hp honda and its on a 20ft pontoon boat its revving 3500 rpms at wide open but dosnt seem to be revving high enough anyone know what it should rev at
Check to Owners Manual. I thi
Check to Owners Manual. I think in general HOndas should be in the 5 - 6 K range at WOT.
Time to lower picth!
"Also, check your tach. Some
"Also, check your tach. Some tachs have settings on the back to match the number of poles in your alternator. Mine was set wrong at the dealer, and read 4000 rpms at WOT. If you have the BF135, your alternator is 4 pole."
"been busy at shop
i messed m
"been busy at shop
i messed my knee up pretty bad, so i have a ton of spare time now"
hi still having a problem with
hi still having a problem with my rpm at wot anyone know what size and pitch i should use on a 20ft pontoon boat still reving 3200rpm checked the tac. its ok useing a 14x15 pitch any suggestions thanks
hey just-in-time tried that im
hey just-in-time tried that im in the process of extending the plate to raise the motor even higher by looking how they are suppose to sit on the transam i need to raise it another 4inchs but not sure if that will get me my rpms
