What prop
kmwracer
How can I find the correct pro
How can I find the correct prop to run on a Evinrude 35 hp serial #E35ELCTS. It is on a 16 ft. v hull Sea Nymph Fishing Machine with a transom hight of 21 in.
"Don, your rigged weight shoul
"Don, your rigged weight should be about 750 pounds (boat, motor, battery, gas). Add a couple of guys, with junk for the day, fishing gear etc, you are probably tipping the scales somewhere around 1300 pounds (fair estimate).
Taking all that into account, the prop calculator says you can run a 15 pitch with that set-up and get good results....
If you run a little heavier (200 pounds more on average) than what I (guessed) at, you may want to move down to a 13."
