What makes reverse rotation engine work
searay57
"Hello,
I have a searay wi
"Hello,
I have a searay with two inboard chevy 350's one cw rotation one ccw rotation.
I am interested in learning how the reverse rotation engine works. what parts are difrent from a standard engine?"
"Jeff
Main difference is the
"Jeff
Main difference is the Camshaft,there are other things like starter motor and distributor, timing marks ect when applied to a carburetor engine.
Cheers
Peter C"
We build GM front covers and t
We build GM front covers and the seals are different. There are ribs in the rubber and they run the other way in reverse rotation engines.
"Ayuh,......
The Timing Cha
"Ayuh,......
The Timing Chain is replaced with a set of Timing Gears......
Consequently,.......
The Crankshaft turns backwards,+ Everything else turns the same way it did before.......
Btw,.....
The Disturbuters are the Same....."
"Bondo
So, what about the e
"Bondo
So, what about the engines that are gear driven to start with and have a Vac advance unit on the Distributor ?
Cheers
Peter C"
"[b]"two inboard chevy 350
""two inboard chevy 350's "
Donno,.......
I'm just telling ya what I know about Marine Chevies......."
"The pistons are also installe
"The pistons are also installed the other way around, so the offset is going in the right direction.
JEff"
It would seem (to me anywa
It would seem (to me anyway) simpler to accomplish the reverse rotation in the gear box. We sell very few reverse rotation cover/seal assemblies so either they are not being used or the wrong seal is being used.
