What is the problem
J
john lech
Guest
"i have a mercruiser 4 cyl 120
"i have a mercruiser 4 cyl 120 hsp i/o that turns but will not start , its getting gas, has spark,had carb rebuilt, and still just turns, what could be wrong ? can you also tell me what ignition part numbers i need to order for the ignition, the distributor number is a j1171. thanks"
"I have a 86-87 60hp mercury t
"I have a 86-87 60hp mercury that was running fine. I was running full throttle when it sounded like the prop broke loose, which it did not. It lost power and stalled and now it starts out of gear but when I go to put it in gear it stalls out"
More to go on. I pulled the th
More to go on. I pulled the three spark plugs and found that two had oil/gas residue and one was dry. What does this mean?
