What control box can i use
eric
" i have a 1974-76 Chrysler 60
" i have a 1974-76 Chrysler 60 HP outboard but i have no control box what exactly should i look for . where i live there is a boat junk yard and they have plenty of older model controls but i need to know which one please help, trying to get boat in water by the 4th thanks eric "
" Eric,
I'd gues
" Eric,
I'd guess, as with any other outboard, that you just have to find a Chrysler control box in the approx. year range that has the correct options (ie if you need power trim, electric choke, electric start etc.). There are a bunch of aftermarket controls out there and kits that come with them for just about any outboard or I/O, these start at about $90 (on the top end, the sky is the limit). If you need cables it's about $30 a piece. The problem you run into with aftermarket stuff is the wiring harness.. I'd probably start by stopping in at that salvage yard and asking about controls (wiring harness, cables, box) for a mid 70's Chrysler with the options you require.
Jon "
" Eric
I have a 78 model Ch
" Eric
I have a 78 model Chrysler Charger 140hp with the control box. The motor has 2 bad cylinders, but the control box, power trim, starter - everything is fine. Let me know if you're interested. "
