sturgeon_general
"Since I had no replys to my m
"Since I had no replys to my most recent post,I'll look for answers in a more basic simple manner.Lets start with I have a powerhead of a 1983,35HP,long shaft,manual start,Johnson,model no.#J35RCTS.I suspect has internal water flow(circulation)problems,affecting the water pumps ability to work correctly.What are water restrictors and there function in engine cooling???What does a damaged restrictor needing replacement,look like.What signs do I look for???Would a bad restrictor affect a water pumps ability to pump water??Correct me if I'm leaving any steps or processes to troubleshooting out before I pass judgement on "water restrictors" as my problem.I really don't want to remove cylinder cover,gasket,thermostat after I've already replaced with new parts and engine runs well,but doesn't pump water.I'm very confindent the water pump is good(replaced recently and worked fine).When powerhead was reinstalled water tube was positioned correctly to fit in water tube grommet.Any suggestions or advice would be greatly appreciated ASAP because I'm contemplating emergency surgery sometime this weekend,thanx THE STURGEON GENERAL."
