"Ike;
Opinions vary on the oi
"Ike;
Opinions vary on the oil issue.
Most agree that a boat engine typically works harder than a car or truck engine. It is usually running at 50-75% of full power, whereas a car engine rarely sees more than 15-20% power. This is why boats get such lousy mileage.
The higher power creates more stress and heat and can cause thinner oils to shear and breakdown, thus leaving you with insufficient lubrication. For this reason boats, as well as aircraft, and motorcycle oils are typically specced at higher viscoisty blends so as to minimize wear and provide more safety margin in high heat situations.
Merc inboard and sterndrive oil is a 25W-40 blend, available either as a pure dino oil, or a semi-synthetic blend. There is no magic in Merc oil as such, but you would be well advised to use a 25W-40 or similar blend, whatever brand you choose.
Thinner oils such as 5W-30 are typically used for ease of starting in extreme temperatures (they are thinner oils), and more recently to provide marginally better fuel consumption in cars and trucks.
Rod"
