T
the_fox_den
Guest
"I have 2001 crusader 7.4MPI&#
"I have 2001 crusader 7.4MPI's they began to get hard to start finally one just ran very rough before I wasn't able to get it restarted. I checked the plags for fouling and found both had plags that were fouled. The engines are fresh rebuilds and the builders used a NGK plug that was not called for by the MFG. One of the motors plugs were wet and slightly rusting as the motor sat for about two weeks. I replaced plugs in both motors and one ran fine, the engine which had the water wet plugs still won't start. What causes water to get on the plugs and have I damaged something. These motors have only 7 hours on them. Help please!"
