I have a 1999 Suzuki DF 70. Current problem is a BEEP (alarm).
As soon as I turn the key to the ON position, there is a long beep and the CHECK ENGINE, OIL, and LIMIT lights, light up on the tach.
The the LIMIT light stays on and the needle goes to 4000rpm. The light goes off and the needle goes back to zero.
Then I have a long single beep every 5-7 seconds with no lights, no codes.
I also have the same long single beep every 5-7 seconds with the engine running.
I have performed the 'Oil Change Reminder" reset
I checked battery voltage with the engine OFF and i have 12.26V.
I own the Suzuki Diagnostic software Version 7.0. It shows no errors or faults.
