I have had the Weber conversion for my AQ151C for a couple of years now and I’ve found the hesitation at the transition of high and low speed jets to be a fact, and I believe it may be a carb design flaw in that the tuning of the low-speed circuit is so very critical. Try this: tune your carb using the directions, making very sure that the idle set screw is not scheduling the throttle plates. If it is, your settings will be out. Then, go out on the water and see how it performs. Then, turn the low speed jet screws (2) ¼ turn richer and see how the transition works. Then, set the screws back to your before the ¼ turn rich and then 1/8 turn leaner. Try a throttle advance and see if there is a difference in ‘smoothness’. If you find an improvement try leaning the screws minutely until the engine runs too rough. I have found that the leanest possible setting to be the best.
I believe that the shipped and available low-speed jets are too large for our engines. But, I’ve also found that the problem is not so pronounced when the engine has been run some time at a high power setting and it is up to operating temperature.
Keep us informed!
