I have a 1980 Johnson 70hp. It runs well , good comp across the cylinders . We have just fitted it up to our small speedboat and in the process replaced the waterpump, thermostat , fuel pump, rebuilt the carbs and generally serviced it. The first time we went out it ran well , good telltale flow, no problems, Second time we went out the tell tale had become very weak , so I removed the leg and puller the pump apart. I had put the impeller wedge keyway in back to front and it was not locking up. Turned it around and reassembled. I had more flow but still no where like it was. I put a hose \on the water tube and it was the same pressure as the pump, weak flow but a lot of water escaping down the leg and I could hear it escaping inside the leg near the powerhead.
I googled away and figured that I may have issues with the exhaust tube and water feed tube as the inside of the leg is very wet with black oil ( i assume it is wet sooty exhaust residue)
I have removed the powerhead and the gasket is a bit ordinary, can't really see any problems there, corrosion is minimal. This engine was a salt water motor before and now runs fresh only so I thought I may have washed away some corrosion and cuased leaks. I want to remove the internal exhaust/water tube assembly and undid the four bolt holding it in , All four have snapped off . There are some rubber mounts in there attached to the steering arm and I undid the bolts that hold them.
Questions
How do I remove the tube from here ??
I tried to remove the plates on the side by the lower rubber mounts but again the bolts started to snap off, I tried to remove the rear bolts on those mounts(9/16" head) but the will not budge
Anything I am missing ?
Any tips or diagrams?
I have a manual but it has nothing on the leg section that I am working on
Thanks in advance
Shaun
Questions
Thanks in advance
Shaun
