Watter in carburetori need additive or
makbat
"Volvo penta 4.3 GL the carbur
"Volvo penta 4.3 GL the carburetor is full with watter and the performance of the engine is hell. In my country the fuel is very bad. Or there is some other problem,so please help me!"
"Well,..........
Gasoline e
"Well,..........
Gasoline engines will Not run on Water,......
I'm Sure that's a major contributing factor in the fact that the motor runs Poorly........"
"I know that gas eng. will no
"I know that gas eng. will no run on water, u r making fun of me? :) Beacouse there is watter in the fuel i need some brands of additives that are good for "fighting" the water in the gas."
"best bet is add a water seper
"best bet is add a water seperating filter before engine. several types available. if you have bad fuel quality, I recommend a racor, or similar that has a clear bowl at the bottom. You can see water without removing filter element. a little more expensive, but worth it."
"I'm Not making fun of you
"I'm Not making fun of you,.....
But,..
Regardless of what fuel is available to you,.....
If you Don't fill the tank with Water,.....
You'll save Alot of Problems like the 1 you're having Now......
There are No Additives that'll Fix Water Contaminated Gas.....
Either Filter it Better,.... Or find another source for your Fuel......
If things are that Bad where you are,....
Try Filtering your fuel Before it's put into the boat,+ as Scott says,.... Add More Filtering between the Tank,+ the Carb......"
"Tnx a lot <[img]"http://www.m
"Tnx a lot
"Something else...i forgot, on
"Something else...i forgot, on the 1999 Volvo penta 4.3 GL, is there fuel/filter water separator allready installed or i have to get it...and some web sites for that part,thanks a lot.
BTW Fuel in Macedonia(my country) is HELL
