I'm about to order a new waterpump kit for my 87 baretta with a 165 hp 4 cyl alpha 1 gen 1 outdrive. Just wondering if there is anything else I should go ahead and replace that is a common wear point while I have the boat apart. I'm having small shifting problems but I think its the shift interupter switch as the boat does not die. And shifts easily after you first start it either forward or reverse and seems to get stuck in gear. Any way I was just wondering if there any other componets I should order before tearing it down. Thanks in advance for your help
