Water wont pump up and pee ?
Maybe water pressure could push right up to the pee hole if you haven't got the impeller fitted but I disagree with testing the pump system on muffs. As it turned out the whole new pump totally fixed my problem.
My point was that you cannot test the operation of the pump on muffs. You can only test that the pump is allowing water to flow from the muffs to the powerhead. That doesn't mean the pump is pulling it in from the intake screen and PUMPING it up there, only that the pump is ALLOWING it to go up there.
