Water tube upper end
Howdy, Out Sportfisher 5 HP is pumping water with a drill on the shaft in a bucket but when we put it on, we get no water discharge. That is after carefully making sure its aligned correctly. Everything is clean and not plugged. The upper end of the tube seems to just dead end against the bottom of the crank case. Any thoughts, anyone?
Kindly, David
Thanks, Racerone. See attached.
What do you think? Shouldn't we be seeing a discharge of the water coming out of the holes in the column? We were very careful to get the tube inserted correctly. One of the area "old-timers" says that sometimes there can be, what he called, a skin flap of rubber that comes from somewhere in the pump. I wasn't quite sure what he was describing. But we didn't see anything that qualified.
