I have a Mercury Optimax 115 hp from 2005. The motor has had a full service where the impeller was replaced with a new one. During the first use of the motor after service, I got an overheating alarm. Since the impeller was new I proceeded to replace the thermostat and the poppet valve with new ones.
I cleaned the engine with a descaler fluid and all went well when I did a test run on land. But in the water I still got the overheating alarm. I then proceeded to clean the water strainer but it broke off when I tried to remove it from the engine.
When we tried to remove what was left of the strainer the plastic that was left in the threads was so frail that the strainer tube fell into the motor.
Do you know the easiest way to get the strainer tube out from the motor?
Best regards,
/Erik
Best regards,
/Erik
