Water restriction on johnson 30hr
jerry_smalley
"I have a 1988 johnson 30hr ou
"I have a 1988 johnson 30hr outboard that starts up fine and runs good and pump water out the pee hole. Once it get warm the water stops coming out the pee hole and steam starts coming out. I have replace the water pump and check the thermostat, and the problem continued, I even took the thermostat out, but this didn't stop the problem either. I have pulled the head to see if there was any restriction, but couldn't find any. I have been told that there is a flap in the water jacket area that can mess up, but I don't know where it would be or if there is one. Any help would be most appreciated. Thanks."
"inner exhaust cvr-- 48--
248182.png"" alt=""
"Is this a common problem? Is
"Is this a common problem? Is the inner exhaust cvr replaceable, and if it is, can you tell me the part #. Thanks you for all your help."
this i not a common prob---mor
this i not a common prob---more common--on 3 cyl----the part #'s can be found at--shop.evinrude.com
