Aaarrggh ! Water dripping from the pulley shaft seal !!!
I just removed this pump 5-6 engine hours ago, which is in a b*tchy location, to inspect / replace the impeller ( bloody knuckles, contorted position to reach it , a lot of cursing ! ) The seal had never leaked and looked fine when dis-assembled..
This is one of those, air purge water pumps - so it's $$$$ to replace.
My questions:
- Can the shaft / seal be rebuilt on this pump if the housing is fine ? Is it advisable ? The pump otherwise is in perfect condition i.e. impeller contact areas are not gouged...
- My serpentine belt felt like it had the right tension when I re-assembeled it the first time - could this have been too tight and blown the seal ? Again, I was very content with the tension - 1/2" flex
- The replacement water pump is pricey and I know some people use a regular water pump when this one goes - any issues with this ?
Thanks,
Bloody-knuckles II
My questions:
Thanks,
Bloody-knuckles II
