M
Mike W
Guest
" Hello! I have a Merc 110 9.
" Hello! I have a Merc 110 9.8 horse. I had it out for the first time this year. While cruising around I noticed very little to no water coming out of the side pee hole....but a fairly steady splash coming out of the exhaust port.
Last year I remember a steady stream coming out of the pee hole, but I didn't use the boat until later in the year when the water was warmer. Now the water is quite cold...like 40 degrees. Would the cooler water cause less water coming out of the pee hole because of the thermostat?
Even at full throttle for 5-10 minutes today...the most I ever got out of the pee hole was a tiny trickle...I'm a bit worried. Why would I be getting water out of only the ports by the exhaust and not the pee hole?
Also, does anyone know if the Merc 110 9.8 has an auto - overheat shut-off?
Thanks!
Mike W "
Thanks!
Mike W "
