Water Pump Question
gjackman
"Does the water pump need to b
"Does the water pump need to be replaced like a maintenance item such as plugs, or only when it isn't working. I bought my boat and motor 3 years ago, the guy I bought it from said he had just replaced the water pump and also gave me a new spare one. I have never had a overheat problem and the stream in the telltail is always strong.
Any comments out there?"
"Water pump impeller and housi
"Water pump impeller and housing are made of rubber, on some make and models,its critical to the life of your engine. Your call.
I replace mine every year as part of my annual maintenance."
"If the engine is used often,
"If the engine is used often, even though the water pressure (gauge if present and visually) appears good, it's a good idea to drop the lower unit every couple of years to inspect the pump assembly.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
