Hello.
I have a Tohatsu 55hp M55B that I have had in the water once. I was suspicious that the water pump was a bit average to after six months of sitting around, I dropped the bottom half and replaced the impeller (two fins missing and I found the fins). Anyway, to cut a long story short, I could not get water out of the tell tale. I took the pump off again and I now have the garden hose connected to the pipe that goes straight up to the moter form the pump. I can turn the hose pipe on full and it builds up enough pressure to blow the hose pipe off before any water gets up to the engine. I have removed the thermostat and the side plate that the temp gauge and tell tale pipe is connected to and no water in these areas. Is there some sort of filter or shut off valve at the top of the pipe from the water pump? I can faintly hear gurgling sounds from the plate where the tell tale was if I pull the hose pipe off the bottom pipe and put it back on again. I would of thought that I would get water gushing out the top of the engine if I have mains water pressure pumping up the pipe from the pump.
Any ideas would be greatly appreciated.
Best regards,
Scott.
Best regards,
Scott.
