water pump help
badbilly64
hi all I just purchased a mid 80s 15hp 2stroke evinrude.it runs good but I only run it about 30 sec.because no water comes out the pee-hole.air comes out so what do I need to check?thanks,I really want to go fishing
Unless you know the history of the water pump I would drop the lower unit and have a look at it. Also check the grommets.
Bill
If you are trying to run your motor in a tub make sure the water level is well above the intake holes; the pump is not self priming and water must be above the pump for it to work.
