freebeerisgood
1999 7.4l I/O
Water pump was about 60hrs/2 yrs old when it failed. I have changed them regularly and having owned the motor a long time, it's occasional failure doesn't surprise me one bit.
That said, prior to noticing the failure after I pulled it out of the water and attempted to flush the engine, there was a unique symptom/sign of it failing that I haven't seen before, and Im curious if its common.
About 10 miles out from the marina, I had some fuel flow issues (indicated at least) in my flow scan gauge. Fuel flow began to become erratic, dropping to 3-4 GPH from about 16 at cruise. I never noticed the engine act up, just a indicated change.
Ultimately I want to know if anyone has seen this caused by a water pump starting to fail, as I have yet to see that prior to it failing?
It has a Fuel/Raw water pump combo of course, and the engine never changed normal operating temperature prior to pulling it out of the water and attempting to flush, when I noticed it was not pulling in water, and checked the impeller and found it had failed.
Any experiences with this would be interesting to hear.
