"Hi Gang,
A pal took his 80&
"Hi Gang,
A pal took his 80's boat with a M/C 120 hp I/O to a shop to address an O/heat issue. They repl. the drive pump {water pump] along with a T/stat,recirc pump belt etc. On his first run the boat overheated just as before. They now tell him it needs a riser which is clogged.However they tell him that the 2 day old water pump needs repl because of the clogged riser. Can a clogged riser somehow affect a new w/pump. Somehow I don't think so. Any thoughts? Thanks Jon Allen"
A pal took his 80&
"Hi Gang,
