A few days ago I asked about dropping the lower unit to get at the water pump on my 15 horse merc. The serial number is 0A743570 Model number 1015201GC 1989 MERCURY CANADA 15 M. Well, as you can guess...I have another question. The impeller is not too bad on it, but since I have it apart I am going to replace the impeller, but what seems to be the main problem is the seal sticking up out of the top cover assembly above the impeller. In the process, I was noticing from parts schematics that there are 2 designs of the water pump base under the impeller. Is there any way to figure out which water pump base design I have without removing the water pump base to see the underside where they look different? The seal around the driveshaft looks good, so I really don't want to open that up just to look at the underside. Any ideas where I could find this out? Thanks in advance.
