Just got the boat out to get it ready to go! Its a 1976 15hp evinrude model 15604A. Last year I replaced the water pump and water cover/gasket and spark plugs/coils. Today I rebuilt the carb and the fuel pump and fired it up. It fired up quickly and fairly strong! Buuuuut..... no water coming out the tube. Theres no blockages, so does that mean I really have to change the water pump again? That was a royal PIA last year with the gear linkage unless theres a trick to making that easier. Water pump is all it can be if theres no blockage right?
One other question. And it did this last year and little bit. But at low idle or low speed it will randomly do like a clunk (best way I can explain it) and it will drop rpms and go back up to normal after the clunk/rpm drop. Any easy explanations for that?
