Water pump 85 Johnson 90 Hp
mdellwva
"I have a shop man. but need s
"I have a shop man. but need some more help. on the shaft is a flat spot. i have a small piece looks like a plastic (key). does this go on the shaft & into slot on pump impeller?? I do not see this in the shop man. V-4 1985 90hp Johnson. If so what is the trick to getting this in ? also i broke the plastic elbow for the small hose. what is this & where can i get this elbow. does this just push in? I will try to show photos of these things. Thank you for any help you can give me. Mike.
"that plastic 90,is for ur spe
"that plastic 90,is for ur speedometer....it does just push in,tight fit tho....dealer item...use an easy out or drill bit to remove broken piece."
"OK Thank you very much. All o
"OK Thank you very much. All of you on this site are ( VERY ) helpful. Thanks Have a nice day, Mike"
