Water level stain on hull
Is the stain on the gel coat of a hull made of fiberglass? If so, I've been pleased with the results of using Davis "Fiberglass Stain Remover". It comes in plastic jar labelled "FSR". The product is a gel that I apply with a rag (wearing rubber gloves). It takes a little scrubbing with the rag and leaving it on for a few minutes, but when you come back with a clean dampened rag, the stains come right off.
https://www.davisinstruments.com/product/fsr/
It's a older boat dont think it has any gel coat just fiberglass
If the hull doesn't look like fiberglass strands or matting in resin, it has some kind of gelcoat or paint on it. Bare fiberglass/resin doesn't last long on a hull that's in water for long periods. Post a photo.
I have used white ScotchBrite pads and dish soap- the staining is organic, so you shouldn't need strong chemicals to remove it. Once it's gone, you can polish and wax the hull.
I took "DJR's" advice and got me some of the "FSR" ......super pleased with how it worked almost like magic , some areas took a second application, but was amazed. Next year, end of season, maybe I'll do a before and after pictures.
The active ingredients in FSR are oxalic acid & isopropanol, at 4.5% each. You can buy a powdered product called barkeepers friend for quite a bit less than FSR.
I’ve also used a product called Brilliant Bowl, (a toilet bowl cleaner),available at janitorial supply companies for about a quarter the price of FSR.
It is also possible to buy powdered oxalic acid and mix your own cleaning agent for very little money.
The precautions to take when using it are the same as with FSR.
