Water leaking from head
ggg99
I have just received a 1987 9.9 Johnson,
Started right up. Water is coming out of the peephole as it should be, but also coming up from the lower unit and pouring out under the cover.
Would this be a water pump rebuild needed?
Not a water pump issue.----Post pictures of where the leak is.----Could just need a gasket replaced.-----Base gasket , head gasket, water cover gasket or exhaust cover gaskets.-----Just guessing if I can not see the motor and the leak.
