"Hi again, Got motor running a
"Hi again, Got motor running aftet re-building carb and now have a gasket leaking under engine.Will it take alot to get engine off to fix this,and are gaskets to be had for this motor? It's a 1973 model eska 7.5 deluxe solid state with foreward, reverse; and netural gears. Seems to run good (thanks Tom for you'r help), but I still didn't see water comming out of the pee holes. Just the little water tube on bottom of engine housing... And of course the leaking gasket.This is after i put a new impeller in...Wouldn't the impeller have to be working to be sending water to the little water tube on bottom of engine? . Is that screw with a spring on side of my carb for air/fuel mixing? Mine is fixed jet with out the screw on bottom of fuel bowl..For parts, engine # is 2175949 1 Thanks for any help"
