S
scott simms
Guest
"I have a 1991 performance boa
"I have a 1991 performance boat with twin Mercruiser 454/ Bravo One set ups. My problem is the boat seems to be leaking water in through the steering shaft where it passes through the gimbal housing. I have been told that the engines must be removed to replace seals that are in there. I did some looking around at the marina and found that a lot of Mercruiser gimbal housings (mostly alpha’s, didn’t have any Bravo’s to compare to) had grease fittings at the top which allowed you to pump grease in around the steering shaft. My owners manual actually shows a grease fitting there also, but my housings don’t have them. There are dimples in my housings where the grease fittings would be located though. Being able to pump grease in there, at least in theory, should slow or stop the leak, even if it is only a tempory/patch repair.
Would it be possible (for a cheap, fast repair) to drill and install grease fittings in the gimbal housing where the dimples are located? Would the grease passage be there behind the dimple if you drilled through? Or do they use different housing molds, or drill the entire passage ? Any experience or info on this problem would be most helpful. Thanks."
