"Well, I've replaced my im
"Well, I've replaced my impeller pump. (AQ255a, 280 outdrive) When I run a hose from the pump intake into a bucket of water, my water flow through the engine is fine. When I connect everything and run with the muffs on the outdrive intake, I get no flow at the pump. Well, If I rev it up to 2500-3000 RPM I get water flow, but absolutely nothing at idle. I don't see any visible leaks around the top of the outdrive. Could it be an internal o ring? Or could it just be that I'm not getting proper flow with the muffs? They don't seem to seal well on the drive, lots of water spraying out, but I get steady water flow out of the bottom intake hole on the drive. If I need to replace things internally, I'll probably have it done. Any idea what it should cost to have the drive pulled, and all of the gaskets and seals for the water intake replaced? Thanks!"
