kimberly_anne
"Does anyone know of a water i
"Does anyone know of a water inlet screen for a 1993 Mercury 60hp? A little history, I recently purchased a used boat that was used for fishing in rivers that had very weak pressure coming out of the tell-tale. After replacing the water pump and cleaning out the tell-tale tube I improved it quite a bit but it was still not very strong. I then removed the thermostat and popet valve and found small river gravel behind the popet and the thermostat. Took them out and ran the engine for a short while to allow the gravel/sand to flush out. The tell tale was still weak so I took the tell-tale tube fitting out of the head and replaced the cover for the thermostat with the thermostat and popet removed and ran the engine again. Many small gravel rocks came out of the head. I thought I had it fixed with a good strong tell-tale stream but then and after using the boat this weekend I once again had to flush the small gravel out. I think that it's working its way out of the system. But after searching on the internet for a screen to cover the water inlets on the lower unit I couldn't find one. Does anyone know of someone who makes something to add to the engine to prevent the small gravel and sand particles from getting into the cooling system (a bolt on inlet screen or filter)?"
