Recently discovered water in my 1995 crusader 350 XL raw water cooled engine. Changed the oil n filter within 5 mins there was 2-3 quarts of water in the oil. Motor seems to run fine no knocks or white smoke from exhaust. Temp steady at 160.. obvious motor needs attention. Not sure if intake manifold leaking or exhaust manifolds or risers. Both replaced with oem parts approx 250hrs ago. Boat is docked in fresh water but used in salt water..suggestions would be appreciated before tearing apart this engine. Thank you!
donjoe
donjoe
