Water in Power Trim Hydraulic System
"What years is the boat? the o
"What years is the boat? the one with a plastic base had cracking problems and let in water and oil out sometimes. Could also be a leaking trim cylinder sucking in water.
You'll want to remove and clean the oil resevoir, detach and blow out the lines, you'll have some left in the trim cylinders, it will take a while to flush them."
