"I always check fluids before
"I always check fluids before I take my boat out. Unfortunately, the last time it took it out I did not tighten the dip stick in the outdrive. I did not notice this until after the outing and you guessed it; water entered the outdrive. I immediately drained the oil but I am concerned about water/moisture being trapped and causing corrosion. Any recommendations for removing water/moisture from the outdrive without having to disassembly the entire thing?"
