I know this question comes up a lot, but cant find anything pertaining to my problem. I have an 83 MerCruiser 120 that I just got from a guy and it hasn't been winterized in a couple years or running since then. The oil was milky on the dip stick so I drained the pan and got a quart or two of water out before the oil started coming out. I seen a line of rust on the side of the engine block that looked like it was a drip from either the exhaust manifold or the head gasket so I took the manifold and head off. The head gasket looked good and didn't see any cracks or areas that allowed any kind of blow by. The manifold gasket looked like it was in good shape also but then it tore apart when the manifold came off. I had no water or rust in the cylinders so what is my next step? I have all the old gasket material taken off and surfaces clean up and see no cracks on manifold or head. I looked down each cylinder with pistons in lowest position and see no cracks. What would be my next step or what are anybodys thoughts? I know nothing about the manifold or risers so if someone could give me some input on this as well if there is anything I should be checking there?
Thank you!!
Thank you!!
