Here is the story. Bought a boat last year before winter but never ran it. For the winter I pulled the 4 drain plugs and drained the block. The next weekend I went to run antifreeze through and water was frozen in the impeller so I couldn't winterize it. This past weekend, The boat had a hard time turning over but eventually did. I accidently had the hose hooked up the wrong/output port of the water pump. When I checked the oil it was 1/2 way up the dipstick (way too high) it was clean though. I ran it slightly above idle (realized that I hooked the hose up to the wrong part of the impeller and then switched it back to the intake and then had water coming out the exhaust. The oil now when I checked itwas milky. I drained the oil (10 qts). What do I do now to preserve the engine? Can I run it with new oil briefly without water going through the block? Is the block cracked, head gaskets or exhaust manifolds? How do you differentiate between the three? Is it possible that I pushed water back into the engine by having the hose hooked up to the outlet instead of the intake for the water pump? I hope that is the case but how do I tell that? Any help appreciated. I live in NH so My season is pretty short.
