Both the powerhead-to-leg and cylender head gaskets have been replaced, however, the problem still remains. My mechanic has run out of ideas, so if anyone has experienced this problem I would gladly like some davice.
Hi Justintime: When you say "change the motor" I assume you mean change the oil. How long should I "run it hard" for as I'm afraid to damage the bearings running with water in the oil.change the motor and run it hard
then check the oil again
