Take A Chance
Hello all, new to this.......
HELP! A long story short. I had my port 454 Gen IV engine rebuilt, long block. I was getting sea water in my oil from a sticking valve and was told by the rebuilders that my exhaust was causing the problem. I put new exhaust manifolds on after the rebuild (the other exhaust parts are approx. 2 years old) and while working out the bugs after putting her back together I fould my coolant level going down and water in the oil. I have drained the oil and thinking I might have a stuck valve, did a compression check and fould all cylinders at 150.
Where could this be coming from? Could a riser do this?
Another issue is that I can't seem to get the rpm's up on the engine (before I started getting water in the oil). I'm good to about 24 - 2600 and then nothing more. The plugs were pretty black when I pulled them which made me think maybe my carb (quadrajet) air/fuel mixture wasn't right or something else?
Any input would be greatly appreciatted.....
JP
JP
