Water in oil
bulton
"I have an 2002 Yamaha T8 4-st
"I have an 2002 Yamaha T8 4-stroke. Water in the oil, changed oil and ran at home with hose connection. More water in oil. Flushed oil twice with water each time. Pulled head, inspected gasget, but nothing obvious. Cylinders look good. Could their be a problem in the lower oil sump area or should I just replace the head gasget and run and check for water again? Or is the problem likely more serious."
"If there is nothing obvious,
"If there is nothing obvious, put on a new head gasket and give it another try. If water shows again,start looking for cracks."
