Hello - I am a 1st time user
Hello - I am a 1st time user 73 twins Chrysler 318
After spring launch the port engine ran very rough. Every time I checked the oil level it was increasing. (not gas) Exhaust is clean
Checked all spark plugs and the first plug at the rear of the engine at the riser was wet. Started the engine and pulled the Spark Plug wire from the Cylinder and there was no change.
Performed a Compression Test on all cylinders and this cylinder read 155 . (Highest was 170) There was a spray of water coming out of the spark plug hole. i assume it was during the compression stroke
The exhaust elbow and riser had been separated. not at the exhaust manifold
I believe that the engine block is cracked. To solve this problem is it possible to insert a sleeve in this bad cylinder
Thanks for your help
