"I have a 1985 Mercruiser 140
"I have a 1985 Mercruiser 140 4 cylinder. End of last season I noticed water had got into the oil making it milky. It was ok all season but the last time it ran I noticed the water in the oil. It is always winterized correctly each season. I've owned the boat for 10 years. I originally thought the intake/exhaust manifold was cracked and leaking so I replaced it with a new manifold & gaskets. It evidently was not the problem. The head was also replaced around 5 years ago and a new camshaft a few years ago. Changed the oil and ran engine for 10 min or so and water showed up again. The engine runs good without cutting out or missing and has not been overheated. I don't believe the head is cracked, but will remove it to check. I have been told that the head gasket is the main concern. Any input on other possible causes would be appreciated!"
